maximum outdoor air flow rate (10.0000) < minimum outdoor air flow rate (11.0000)
* ~~~ * To set the minimum outside air flow rate use the "Design (minimum) outdoor air flow rate" field in the Sizing:System object
Bolded line appears to be your error. Your maximum airflow is specified to be lower than the minimum specified airflow.
Bolded line appears to be your error. Your maximum airflow OA flow is specified to be lower than the minimum specified airflow.OA flow.
