The following is what comes up after applying the "Add Daylight Sensor at the Center of Spaces with a Specified Space Type Assigned" measure and then the Radiance Daylighting Measure. Note that several of the spaces of this particular building do not have exterior windows, and the first of the two measures mentioned therefore does not add daylight sensors to those spaces. Perhaps that is the cause for this error.
(Sorry, this is not really an answer, but I did not know how to add an image otherwise).
