1 | initial version |
It's unfortunate you can't post images yet (you need more 'karma points'), as I'm not sure what you mean by 'stiff'. I assume it's a resolution issue. Things to check are the resolution of your illuminance map, and the Radiance simulation settings. If your grid and space are the same as the model in the video, then confirm you are using the "high" quality setting in the Radiance measure. If the results are still unsatisfactory, perhaps you could post some example images on Dropbox or Gdocs or similar?
