This might be a good place to start.
http://pythonhosted.org//eppy/index.html#
OpenStudio also has Python bindings, and works at a higher level of abstraction.
This might be a A good place to start.
http://pythonhosted.org//eppy/index.html#start might be Eppy.
A good place to start might be Eppy. There's a good high-level introduction to what Eppy is and can do on Github.
Also, something the author, Santosh Philip said in a release email (April 2014) about Eppy's background:
"Eppy was developed over the last year, for the ASHRAE 1651-RP research project that required modifying large number of files and analyzing the results.
Eppy was partially funded by ASHRAE and the original code was written in 2004 as a text interface for Energyplus and the scripting language was built on it's foundations."
The open source license was GPLv3, but as of v0.5.0 it is MIT.
