There is no direct way to add custom HVAC templates by extending the GUI. The best way to make a custom HVAC template is to write a measure to add the system. The measure could pull in pre-build systems from a resource OSM, or they could build the system on the fly. In either case they can optionally connect existing model objects to the new system.
