Eppy can create a diagram of the plant loops using the eppy/useful_scripts/loopdiagram.py script. Running it on the 5ZoneSwimmingPool.idf example file produces this diagram. I've used this quite a bit in debugging plant layout issues before so it may be useful to you.
It looks like the pool Test Pool is just connected to the HW Demand loop on its own branch in parallel with the other heating zones.
