The material libraries for the various buildings can be found at:
C:\Program Files\OpenStudio 1.11.0\share\openstudio-1.11.0\OSApp
If you open one of these in a text editor, you can see how things are set up. You can follow much of the same process as is shown at:
https://www.youtube.com/watch?v=DeAbTl_h8fM (make sure you turn on your closed captions so you can follow what each step is doing)
Save your new, custom library with a new name (making sure not to alter the existing libraries)
Then, in OpenStudio, go to File > Load Library
Assuming you have done everything correctly, you should have your newly created library to choose from.
I am hoping that there is a better method, using something in the OpenStudio interface, which is much more user friendly, but this one seems to work.
