How confident are you in the plant loop settings? I'm not familiar with 'Zone HVAC Baseboard Rad Conv Water', but many plant operation/consumption issues can be traced back to default plant loop settings. https://unmethours.com/question/17388/loop-design-temperature-difference/
Also, many modelers recommend adding extra adiabatic piping to plant loops.
https://unmethours.com/question/11297/openstudio-should-you-add-adiabatic-pipes-and-bypass-branches-manually/
