How did you run this measure? Was it part of a PAT workflow, or was is a single measure run in the app? It looks like there should be log messages returned to you whether the measure was successful or not. It looks like this measure is designed to fail if some of the user inputs are bad or deemed incorrect. If the measure is claiming success and you are not seeing any change in the results (or any sensors added), then there may be a bug in the works here. Can you share a download link to your model?
