There may be faster ways to do this, but I made a measure to export hourly .csv data for meters and variables.
Add the AddMeter measure to your model:
Then add the ExportMetertoCSV measure:
Once you runt he model, a .csv file will be available in the run -> UserScript -> directory for that measure:
Once you runt he run the model, a .csv file will be available in the run -> UserScript -> directory for that measure:
Once you run the model, a .csv file will be available in the run -> UserScript -> directory for that measure:
EDIT: Other ways to do this: - Open the .eso file with DesignBuilder ResultsViewer. - I built a little python script to do this for VARIABLES (not METERS) if it's just a few variables and I don't want to bother with other things. You could easy adapt it to meters if you can tinker with code.
| 4 | No.4 Revision |
EDIT:
Other ways to do this: this:
| 5 | No.5 Revision |
