Maybe the ISO 13790 can help you to decide. "In particular you have not to dived a space in more thermal zone if 1. Set-point temperatures for heatingcooling of the spaces differ by no more than 4 K; 2. The spaces is serviced by the same heating systeme (if any) and the same cooling system (if any); 3. At least 80% of the floor area are serviced by the same ventilation system; 4. The ammount of ventilation (in cubic metre per square metre of floor area per second) differs by not more than a factor of 4 within 80% of the floor area."
"In decide.
"*In particular you have not to dived a space in more thermal zone if
1. if
2. K;
3. any);
4. system;
The ammount of ventilation (in cubic metre per square metre of floor area per second) differs by not more than a factor of 4 within 80% of the floor area."area.*"
"*In particular you have not to dived a space in more thermal zone ifif:
The ammount of ventilation (in cubic metre per square metre of floor area per second) differs by not more than a factor of 4 within 80% of the floor area.*"
| 4 | No.4 Revision |
"*In "In particular you have not to dived a space in more thermal zone if:
The ammount of ventilation (in cubic metre per square metre of floor area per second) differs by not more than a factor of 4 within 80% of the floor area.*"area."
