I believe the set point manger should be placed on the node downstream of the tank. You need to create a schedule in the schedule tap in the OS to set up the targeted temperature for example 45.4 F. You can find more detail of chilled water tank example in E+ example files:5ZoneVAV-ChilledWaterStorage-Mixed.idf 5ZoneVAV-ChilledWaterStorage-Mixed_DCV_MaxZd.idf 5ZoneVAV-ChilledWaterStorage-Mixed_DCV_MultiPath.idf 5ZoneVAV-ChilledWaterStorage-Stratified.idf
The outputs, you can use either OS output variable measure or in the E+, running the simulation first then request desired output variables.
