Thank you for your answers.
Following the advise of Nathanael, I tried to increase -lr and decrease -lw. My aim is to generate the same illuminance value without the use of the ambient file as I get using it.
I have tried -ab 500 -lr 1000 -lw 0.000000001. The results are still (for zone 2):
With ambient file (created in rtrace for zone 1): 211.394704
Without ambient file: 203.645436
The new run.bat file is:
echo This result file is to show that usage of ambient file increases illuminance > res.txt
gensky -ang 0 45 -b 22.86 -c -m 0 -g 0.2 > sky.mat
oconv sky.mat sky.rad materials.mat zone1.rad zone2.rad shade.rad > scene.oct
echo Zone 1 without ambient file >> res.txt
rtrace -ab 5 -h -I+ -ov -u- -faa scene.oct < p1.pnt | rcalc -ia -oa -e $1=179*(0.265*$1+0.67*$2+0.065*$3); >> res.txt
echo Zone 2 without ambient file >> res.txt
rtrace -ab 5 -h -I+ -ov -u- -faa scene.oct < p2.pnt | rcalc -ia -oa -e $1=179*(0.265*$1+0.67*$2+0.065*$3); >> res.txt
echo Zone 1 without ambient file but with large ab >> res.txt
rtrace -ab 500 -lr 1000 -lw 0.000000001 -h -I+ -ov -u- -faa scene.oct < p1.pnt | rcalc -ia -oa -e $1=179*(0.265*$1+0.67*$2+0.065*$3); >> res.txt
echo Zone 2 without ambient file but with large ab >> res.txt
rtrace -ab 500 -lr 1000 -lw 0.000000001 -h -I+ -ov -u- -faa scene.oct < p2.pnt | rcalc -ia -oa -e $1=179*(0.265*$1+0.67*$2+0.065*$3); >> res.txt
echo Zone 1 with ambient file >> res.txt
rtrace -ab 5 -h -I+ -ov -u- -faa -af ambf.amb scene.oct < p1.pnt | rcalc -ia -oa -e $1=179*(0.265*$1+0.67*$2+0.065*$3); >> res.txt
echo Zone 2 with ambient file >> res.txt
rtrace -ab 5 -h -I+ -ov -u- -faa -af ambf.amb scene.oct < p2.pnt | rcalc -ia -oa -e $1=179*(0.265*$1+0.67*$2+0.065*$3); >> res.txt
echo The illuminance in zone 2 is higher when using ambient files than without it. Such a high value can not be achieved by using a very large ab. >> res.txt
del ambf.amb
del scene.oct
del sky.mat
The result file is:
189.745012
193.791486
195.498072
203.645436
189.745012
211.394704
So I am closer than before, but still not there.
del ambf.amb
del scene.oct
del sky.mat
The result file is:
189.745012
193.791486
195.498072
203.645436
189.745012
211.394704
