The OS CLI is in early development. We expect it will be available in the Jun-Aug time frame. The OS server code is also undergoing a significant refactor in that same period of time. One change is to move it to the Docker framework to make it easier to deploy on different platforms. I recommend following the appropriate OpenStudio repositories to stay abreast of these developments as they unfold in the next few months.
The CLI was officially released in OS CLI 2.0.0 in December of 2016.
OpenStudio server is in early development. We expect it will be available in the Jun-Aug time frame. The OS server code is also undergoing a significant docker-based refactor in that same period of time. the January 2017 timeframe. One change This is to move it to the Docker framework intended to make it easier to deploy OpenStudio on different platforms. platforms other than AWS. I recommend following the appropriate OpenStudio repositories to stay abreast of these developments as they unfold The first major release for this refactored code will be 2.1.0 in the next few months. March 2017.
