Try using the surface matching and intersecting measure in the stand alone application instead of the SketchUp plugin. Ideally with a clean copy of your model. We have updated it to do base surface intersections. It won't create new subsurface.
Keep in mind that if you do intend to have interior subsurfaces, OpenStudio won't find surface match unless the subsurface exists in both surfaces.
Keep in mind that if you do intend to have interior subsurfaces, OpenStudio won't find surface match unless the subsurface exists in both surfaces. link to post with details on the new functionality of surface match measure.
