Did some testing with the current release. I did notice an error for daily delta temperature (converting from C to F instead of K to R), I'll file an issue for that, will be in next iteration installer. But other than that seems to show data as expected. I would be interested to know what version of OpenStudio made the report.
As far as the issue with area, that please describe what you are seeing in new post, there are a couple situations where the EnergyPlus area may not match the OpenStudio area, such as if you have many spaces stacked that are all part of the same thermal zone.
Did some testing with the current release. I did notice an error for daily delta temperature (converting from C to F instead of K to R), I'll file an issue issue for that, will be in next iteration installer. But other than that seems to show data as expected. I would be interested to know what version of OpenStudio made the report.
As far as the issue with area, please describe what you are seeing in new post, there are a couple situations where the EnergyPlus area may not match the OpenStudio area, such as if you have many spaces stacked that are all part of the same thermal zone.
| 4 | No.4 Revision |
As far as the issue with area, please describe what you are seeing in new post, there are a couple situations where the EnergyPlus area may not match the OpenStudio area, such as if you have many spaces stacked that are all part of the same thermal zone.may want to check out this post before making a new one.
| 5 | No.5 Revision |
Here is a screenshot of where to inspect design days in the GUI.
As far as the issue with area, please describe what you are seeing in new post, there are a couple situations where the EnergyPlus area may not match the OpenStudio area, may want to check out this post before making a new one.
