For refrigeration equipment, you should enter the same performance for your baseline as what you are using in the proposed model. There is no explicit way of getting credit for high performance refrigeration equipment in Appendix G (Standard 90.1-2004 thru 90.1-2013).
For some organizations that reference Appendix G, you may be able to make a special request to get credit for refrigeration equipment is higher performance than what is typically installed in buildings. That would be up to the individual organization.
