"Maximum Hot Water or Steam Flow Rate {m3/s}" input field in unit heater object should have "Autosize" instead of blank. That successfully completes the simulation.
ZoneHVAC:UnitHeater,
1-Stair-A Zn Unit Heater, !- Name
Always On Discrete, !- Availability Schedule Name
Node 1235, !- Air Inlet Node Name
Node 1236, !- Air Outlet Node Name
Fan:ConstantVolume, !- Supply Air Fan Object Type
1-Stair-A Zn Unit Heater Fan, !- Supply Air Fan Name
Autosize, !- Maximum Supply Air Flow Rate {m3/s}
Coil:Heating:Water, !- Heating Coil Object Type
1-Stair-A Zn Unit Heater Heating Coil, !- Heating Coil Name
, !- Supply Air Fan Operating Mode Schedule Name
No, !- Supply Air Fan Operation During No Heating
autosize, !- Maximum Hot Water or Steam Flow Rate {m3/s}
0, !- Minimum Hot Water or Steam Flow Rate {m3/s}
0.001; !- Heating Convergence Tolerance
