1 | initial version |
Infiltration is typically defined from the Space Types Tab (5th from top). You'll see these these on the Spaces Tab (7th from top) under the Loads subtab. These will typically be in green text to designate that the values were inherited from the Space Type definition. You can choose to redefine the values used in the Space Type definition.
2 | No.2 Revision |
Infiltration is typically defined from the Space Types Tab (5th from top). You'll see these these on the Spaces Tab (7th from top) under the Loads subtab. These will typically be in green text to designate that the values were inherited from the Space Type definition. You can choose to redefine the values used in the Space Type definition. Tabs.
