Hi,
Thanks for the tip, it worked.
In case, someone else would like to repeat:
Modify the Density value if required (use the preview button to check mesh density)
In Sketchup, File>Import
The imported geometry will be grouped so select the geometry and right-click then explode
Click the first zone and right-click then explode again
Note: The imported Rhino geometry included coplanar surfaces for the windows but these did not import correctly. I deleted the surfaces and added the windows manually to the Space objects in Sketchup.
