Hi nadish,
I think you can leave the mixer out (if E+ complains, keep it and only connect the first zone.) The airflow between the other zones and the living room can be modeled as crack flow or flow through a simple or detailed component with venting availability schedules on the surfaces of those leakage components. Are you planning to integrate user behavior? (interzone door opening/closing). I had less time than expected, so I'll have a second look at your question in the morning. Kind regards.
