You can see the envelope (geometry) information from the Envelope Summary in the <filename>.htm file.
You need to add the "EnvelopeSummary" or "AllSummary" to the Output:Table:SummaryReports object.
![]() | 2 | No.2 Revision |
The report is based on surfaces. If you would like to see by construction, in the report, you can see the construction of each surface. So you can simply aggregate them to see the total area for each construction.
