Ultimately the quick fix was figuring out how to use Floorspace. Floorspace doesn't show as an option when importing an Asset Score model, so I created a brand new model. Then I used the same dimensions to create the building space. Doing it this way removed the plenum and I imported the library from the asset score mode so I could still make the model I wanted.
