You can change the last For to "For: AllDays," for all your schedules to get rid of the errors. This will include the weekend which is important for annual energy use. The VRF warnings for Curve output at rated conditions = 1.136 are not an issue.
Schedule:Compact, OCCUPY-1, Fraction, Through: 12/31, For: WeekDays SummerDesignDay, Until: 8:00,0.0, Until: 12:00,1.0, Until: 13:00,0.5, Until: 17:00,1.0, Until: 18:00,0.3, Until: 24:00,0.0, For: Weekends WinterDesignDay Holiday, Until: 24:00,0.0;
Schedule:Compact,
OCCUPY-1,
Fraction,
Through: 12/31,
Until: 8:00,0.0,
Until: 12:00,1.0,
Until: 13:00,0.5,
Until: 17:00,1.0,
Until: 18:00,0.3,
Until: 24:00,0.0,
Until: | 3 | No.3 Revision |
You can change the last For to "For: AllDays," for all your schedules to get rid of the errors. This will include the weekend other day types which is important for annual energy use. The VRF warnings for Curve output at rated conditions = 1.136 are not an issue.
Schedule:Compact,
OCCUPY-1,
Fraction,
Through: 12/31,
Until: 8:00,0.0,
Until: 12:00,1.0,
Until: 13:00,0.5,
Until: 17:00,1.0,
Until: 18:00,0.3,
Until: 24:00,0.0,
Until: 24:00,0.0;
| 4 | No.4 Revision |
You can change the last For to "For: AllDays," AllOtherDays," for all your schedules to get rid of the errors. This will include the other day types which is important for annual energy use. The VRF warnings for Curve output at rated conditions = 1.136 are not an issue.
Schedule:Compact,
OCCUPY-1,
Fraction,
Through: 12/31,
Until: 8:00,0.0,
Until: 12:00,1.0,
Until: 13:00,0.5,
Until: 17:00,1.0,
Until: 18:00,0.3,
Until: 24:00,0.0,
Until: 24:00,0.0;
