@keigo, those curves are used during initialization of the VRF system and only happens 1 time at the beginning of the simulation. Think of these as more of a sizing input for autosizing. Output of these curves is not available during the simulation.
if (CheckVRFCombinationRatio(VRFCond)) {
if (state.dataHVACVarRefFlow->VRF(VRFCond).CoolCombRatioPTR > 0) {
state.dataHVACVarRefFlow->CoolCombinationRatio(VRFCond) = CurveValue(
state, state.dataHVACVarRefFlow->VRF(VRFCond).CoolCombRatioPTR, state.dataHVACVarRefFlow->VRF(VRFCond).CoolingCombinationRatio);
} else {
state.dataHVACVarRefFlow->CoolCombinationRatio(VRFCond) = 1.0;
CheckVRFCombinationRatio(VRFCond) = false;
The results of these curves is shown in the eio file:
if (state.dataHVACVarRefFlow->MyOneTimeEIOFlag) {
static constexpr std::string_view Format_990(
"! <VRF System Information>, VRF System Type, VRF System Name, VRF System Cooling Combination Ratio, VRF "
"System Heating Combination Ratio, VRF System Cooling Piping Correction Factor, VRF System Heating Piping "
"Correction Factor\n");
print(state.files.eio, Format_990);
state.dataHVACVarRefFlow->MyOneTimeEIOFlag = false;
Format_991,
cVRFTypes(state.dataHVACVarRefFlow->VRF(VRFCond).VRFSystemTypeNum),
state.dataHVACVarRefFlow->VRF(VRFCond).Name,
state.dataHVACVarRefFlow->VRF(VRFCond).CoolingCombinationRatio,
state.dataHVACVarRefFlow->VRF(VRFCond).HeatingCombinationRatio,
state.dataHVACVarRefFlow->VRF(VRFCond).PipingCorrectionCooling,
state.dataHVACVarRefFlow->VRF(VRFCond).PipingCorrectionHeating);
