Have you tried using TrackFacilityElectricDemandStoreExcessOnSite for the Storage Operation Scheme? As per the documentation:
TrackFacilityElectricDemandStoreExcessOnSite indicates that storage control will follow the facility power demand (meter Facility:Electricity) while accounting for any on-site generation. Only excess on site generation gets stored. This is the legacy control behavior before version 8.5 and is the default.
Maybe there is a reason you are trying to use a schedule, but the schedule appears to simply try to charge from PV during the day and discharge after the sun goes down. That's basically what the default option will do as well, except that it will only ever charge from the PV.
