For those that are working on radiant cooling panels modeling, I have written an energyplus measure codes to fix the issue.
def get_tzone_of_rad_clg_pnls(rad_pnls: list[openstudio.WorkspaceObject], workspace: openstudio.Workspace) -> dict:
# get all rad pnl in the starting workspace
rad_pnl_dicts = {}
for rad_pnl in rad_pnls:
rad_name_ = rad_pnl.getString(0)
frac_rad_on_ppl_ = rad_pnl.getString(18)
if rad_name_.is_initialized():
rad_name = rad_name_.get()
rad_pnl_dicts[rad_name] = {'idf_obj': rad_pnl}
if frac_rad_on_ppl_.is_initialized():
frac_rad_on_ppl = float(frac_rad_on_ppl_.get())
rad_pnl_dicts[rad_name]['frac_rad_on_ppl'] = frac_rad_on_ppl
# get all the zonehvac equip list
rad_pnl_names = rad_pnl_dicts.keys()
zhvac_equip_lss = workspace.getObjectsByType('ZoneHVAC:EquipmentList')
for zhvac_equip_ls in zhvac_equip_lss:
ext_grps = zhvac_equip_ls.extensibleGroups()
for ext_grp in ext_grps:
zequip_obj_type = str(ext_grp.getString(0))
if zequip_obj_type == 'ZoneHVAC:CoolingPanel:RadiantConvective:Water':
zequip_name = str(ext_grp.getString(1))
if zequip_name in rad_pnl_names:
rad_pnl_dicts[zequip_name]['zone_hvac_equip_list'] = str(zhvac_equip_ls.getString(0))
# get all the zonehvac equip connections and get the zone name
zhvac_equip_conns = workspace.getObjectsByType('ZoneHVAC:EquipmentConnections')
for zhvac_equip_conn in zhvac_equip_conns:
equip_ls_name = str(zhvac_equip_conn.getString(1))
for rad_pnl_name in rad_pnl_names:
equip_ls_name_ref = rad_pnl_dicts[rad_pnl_name]['zone_hvac_equip_list']
if equip_ls_name == equip_ls_name_ref:
tzone_name = str(zhvac_equip_conn.getString(0))
rad_pnl_dicts[rad_pnl_name]['thermal_zone_name'] = tzone_name
break
return rad_pnl_dicts
def run( self, workspace: openstudio.Workspace,
runner: openstudio.measure.OSRunner,
user_arguments: openstudio.measure.OSArgumentMap,):
"""Defines what happens when the measure is run."""
super().run(workspace, runner, user_arguments) # Do **NOT** remove this line
if not (runner.validateUserArguments(self.arguments(workspace), user_arguments)):
return False
rad_pnls = workspace.getObjectsByType('ZoneHVAC:CoolingPanel:RadiantConvective:Water')
# get which thermal zone the radiant panel
rad_pnl_dicts = get_tzone_of_rad_clg_pnls(rad_pnls, workspace, runner)
# report initial condition of workspace
runner.registerInitialCondition(f"The building has {len(rad_pnls)} rad_panels")
# reverse translate the idf into osmod
rev_translate = openstudio.energyplus.ReverseTranslator()
osmod = rev_translate.translateWorkspace(workspace)
# get all the thermal zones
thermal_zones = osmod.getThermalZones()
thermal_zone_name_ref = rad_pnl_dicts[rad_pnl_name]['thermal_zone_name']
# get all the surfaces that is in this zone
sel_tzone = None
for thermal_zone in thermal_zones:
thermal_zone_name = thermal_zone.nameString()
if thermal_zone_name == thermal_zone_name_ref:
sel_tzone = thermal_zone
break
tzone_surfaces = []
tzone_spaces = sel_tzone.spaces()
for tzone_space in tzone_spaces:
tzone_surfaces.extend(tzone_space.surfaces())
# region: calculate all the surface areas of each surface type
ttl_wall_area = 0
ttl_flr_area = 0
ttl_ceil_area = 0
for tzone_srf in tzone_surfaces:
srf_type = str(tzone_srf.surfaceType())
srf_area = tzone_srf.grossArea()
if srf_type == 'Wall':
ttl_wall_area += srf_area
elif srf_type == 'Floor':
ttl_flr_area += srf_area
elif srf_type == 'RoofCeiling':
ttl_ceil_area += srf_area
# endregion: calculate all the surface areas of each surface type
frac_rad_on_ppl = rad_pnl_dicts[rad_pnl_name]['frac_rad_on_ppl']
# Assume that 45% of what is not on people is on the walls
frac_wall = (1.0 - frac_rad_on_ppl) * 0.45
# Assume that 50% of what is not on people is on the floor
frac_floor = (1.0 - frac_rad_on_ppl) * 0.5
# Assume that 5% of what is not on people is on the walls
frac_ceil = (1.0 - frac_rad_on_ppl) * 0.05
rad_pnl_idf = rad_pnl_dicts[rad_pnl_name]['idf_obj']
rad_pnl_idf.clearExtensibleGroups()
ttl_frac = 0
for scnt,tzone_srf in enumerate(tzone_surfaces):
new_grp = rad_pnl_idf.pushExtensibleGroup()
srf_name = tzone_srf.nameString()
new_grp.setString(0, srf_name)
frac_srf = srf_area/ttl_wall_area*frac_wall
frac_srf = srf_area/ttl_flr_area*frac_floor
frac_srf = srf_area/ttl_ceil_area*frac_ceil
ttl_frac+=frac_srf
new_grp.setDouble(1, frac_srf)
runner.registerFinalCondition(f"The building finished with {len(rad_pnls)} zones.")
return True
