This object is not meant to be a component on a branch (e.g., as with a water coil in the AirloopHVAC branch below). This object needs a parent object on the branch to control the operation of the coil and the coil is inside that parent object.
Branch,
SYS0Branch1, !- Name
, !- Pressure Drop Curve Name
AirLoopHVAC:OutdoorAirSystem, !- Component 1 Object Type
SYS0OA System, !- Component 1 Name
SYS0Supply Inlet Node, !- Component 1 Inlet Node Name
SYS0AirLoopMixed Air Node Name, !- Component 1 Outlet Node Name
Coil:Heating:Water, !- Component 2 Object Type
SYS0SHC-1, !- Component 2 Name
SYS0AirLoopMixed Air Node Name, !- Component 2 Inlet Node Name
SYS0SHC-1Outlet Node, !- Component 2 Outlet Node Name
CoilSystem:Cooling:DX, !- Component 3 Object Type
SYS0SCC-1System,!- Component 3 Name
SYS0SHC-1Outlet Node, !- Component 3 Inlet Node Name
SYS0SCC-1Outlet Node, !- Component 3 Outlet Node Name
Fan:SystemModel, !- Component 4 Object Type
SYS0SF-1, !- Component 4 Name
SYS0SCC-1Outlet Node, !- Component 4 Inlet Node Name
SYS0Supply Outlet Node; !- Component 4 Outlet Node Name
