If you're successfully running OpenStudio models with zones having the "Turn On Ideal Air Loads" option, open the (EnergyPlus-generated) run/.rdd file and search (CMD-F) for "ideal". You should get around 60 hits, e.g.:
Output:Variable,*,Zone Ideal Loads Supply Air Sensible Heating Energy,hourly; !- HVAC Sum [J]
Output:Variable,*,Zone Ideal Loads Supply Air Latent Heating Energy,hourly; !- HVAC Sum [J]
Output:Variable,*,Zone Ideal Loads Supply Air Total Heating Energy,hourly; !- HVAC Sum [J]
If you're not able to add these directly in OpenStudio Application's Output Variables tab, open the .osm file using a text editor, and add them directly, e.g.:
OS:Output:Variable,
{1e353f85-11a8-4495-a2ed-be20a1a827a3}, !- Handle
Output Variable 3, !- Name
*, !- Key Value
Zone Ideal Loads Supply Air Sensible Heating Energy, !- Variable Name
Hourly; !- Reporting Frequency
Make sure the handle is unique (change one or more characters if needed). Tested - works. Should do the trick.
