It sounds like you are referring to a walkout basement. The best model in EnergyPlus for this foundation type is Kiva. In fact, if you look at its inputs, it specifically describes how to model a walkout basement using multiple Kiva foundation objects with stepped wall surfaces.
Unfortunately, the OpenStudio Application does not support Kiva right now, so you would need to:
