OK. What are often called storm windows.
Look up the EnergyPlus WindowProperty:StormWindow object. It's pretty straightforward.
Unfortunately, I don't think the OpenStudio SDK supports this feature. You're likely left with either:
straightforward. Unfortunately, I don't think the OpenStudio SDK supports this feature. You're likely left with either:
EDIT, in response to the follow-up comment:
For greater flexibility (e.g. exterior storm window vs extra interior pane), you can always look into the following EMS features to dynamically switch a subsurface's construction:
The EMS "thermochromatic window" example was implemented as an OpenStudio measure 8 years ago. I couldn't get to work after a few tries. Haven't taken a deeper dive, though. However, it does provide step-by-step EMS guidance on how to implement something similar. May help.
OK. What are often called storm windows. Look up the EnergyPlus WindowProperty:StormWindow object. It's pretty straightforward. Unfortunately, I don't think the OpenStudio SDK supports this feature. You're likely left with either:
| 4 | No.4 Revision |
