Hi Adrian, there are a couple of objects you can consider. ChillerHeater. This object is only available as WaterCooled condenser. You can incorporate multiply ChillerHeaters inside the object CentralHeatPumpSystem.
Personally, I have wanted an airsource chillerheater object, but it's not yet available in DesignBuilder. In later versions of EnergyPlus, there is this object, PlantEquipmentOperation:ChillerHeaterChangeover.
Hi Adrian,
there are a couple of objects you can consider. ChillerHeater. This object is only available as WaterCooled condenser. You can incorporate multiply multiple ChillerHeaters inside the object CentralHeatPumpSystem.
