click to hide/show revision 1
initial version
I believe it sizes for the entire load. You can check in the component sizing report. This would make sense because if temperatures fall below of minimum, you still need full capacity.
I believe it sizes for the entire load. You can check in the component sizing report. This would make sense because if temperatures fall below of minimum, the heat pump minimum outdoor air temperature, you still need full capacity.
