If you’re looking for more detail than is provided in the Sketchbox output spreadsheet, I suggest opening up the model file(s) in eQuest 3.64. There you have full control to edit, run, and set up whatever hourly reports you want directly from eQuest. There will be one eQuest file per “shell” plus one just for exterior lighting loads, so this option works best for relatively simple buildings with a small number of shells. This also requires a “Standard” subscription to Sketchbox. If you have the Standard subscription there will be a Download Archive button next to the Download Results button which contains the eQuest files.
