click to hide/show revision 1
initial version
Hi Keigo, I am sorry to open this thread once again. While working on a baseline case following system 8 (appendix G ASHRAE 90.1 2010), there is a requirement for PFP terminal unit. Now I have a couple of queries regarding that: 1. Whether the PFP terminal units are applicable to all zones or only the zone toward the perimeter of the building? 2. We are working on design builder, so there are couple of parameters in PFP box which I am unsure of to input. Parameters like Fan On flow fraction, Maximum primary air flow rate(m3/s), maximum secondary air flow rate(m3/s), and minimum primary air flow fraction. These are currently autosized. Can you help me out in this. Appreciate your help and way forward.
