ExpandObjects reads an in.idf and writes expanded.idf and expandedidf.err files in the same folder.
You might want to take a look at the \workflows\energyplus.py for an example or RunEPlus.bat to understand better.
In general, the note from energyplus.py
# So...ExpandObjects is weird in E+. It doesn't like running things in directories and accidentally symlinks
# things into the current working directory even if you specify an output directory
# We're just going to run it ourselves. (Side note it could be a similar problem for EPMacro)
suggests to me that you might want to just run ExpandObjects prior to running EnergyPlus rather than using the -x approach. Perhaps, put the in.idf into a temporary folder.
