There is a new air-to-water heat pump model that is planned to be included in EnergyPlus 25.2, to be released at the end of September. In particular, you can read its design document to understand existing capabilities/gaps and how the new model will work. This may help you decide if it's worth waiting for the new model or if the existing capabilities are sufficient.
