I believe this is the case for any schedule. A step-by-step:
You should be able to navigate elsewhere (e.g. to another tab), then return back to the modified schedule.
EDIT : Thanks for sharing the .osm file. I had no difficulty adjusting the scheduled setpoint temperatures below 0°C.
Using OpenStudio Application 1.9.0-rc1 on MacOS 15.5 (latest).
