@Shalini_K : There's a slight disconnect between your title (i.e. "how to change window technology in OpenStudio") and the multi-step procedure you're describing in the post itself. I'm inferring from the latter that you're likely more interested in troubleshooting that specific measure, rather than simply replacing window technology in OpenStudio - could be wrong. If measure troubleshooting is indeed what you're after, consider changing the title ...
Otherwise, changing window technology in OpenStudio is pretty straightforward. Essentially what you're describing in STEP 1 - adding a new SimpleGlazingMaterial. Of course, that new material has to be added to a new, single-layer "Simple Glazing" construction. Then you either need to:
Just to be sure, I tested both approaches using OpenStudio v3.9 ... no issues. And so that's it - you don't need a measure (STEP 2) to substitute window technology using OpenStudio ...
Hard to pinpoint where the issue(s) may lie in STEP 2 (measure vs your model) without having the OSM on hand. The measure itself has interesting features (e.g. LCC), yet some limitations (e.g. no skylights, no glass doors). If you're not planning to use these features or are possibly hindered by these limitations, then using the measure may be a tad overkill.
STEP 3 is a bit confusing, and holds in fact 3 separate questions:
Again, without knowing more or having access to the OSM, hard to pinpoint issues/fixes. Hope this helps, though.
@Shalini_K : There's a slight disconnect between your title (i.e. "how to change window technology technologies in OpenStudio") and the multi-step procedure you're describing in the post itself. I'm inferring from the latter that you're likely more interested in troubleshooting that specific measure, rather than simply replacing window technology technologies in OpenStudio - could be wrong. If measure troubleshooting is indeed what you're after, consider changing the title ...
Just to be sure, I tested both approaches using OpenStudio v3.9 ... no issues. And so that's it - you don't need a measure (STEP 2) to substitute window technology technologies using OpenStudio ...
Hard to pinpoint where the issue(s) may lie in STEP 2 (measure vs your model) without having the your OSM on hand. The measure itself has interesting features (e.g. LCC), yet some limitations (e.g. no skylights, no glass doors). If you're not planning to use these features or are possibly hindered by these limitations, then using the measure may be a tad overkill.
@Shalini_K : There's a slight disconnect between your title (i.e. "how to change window technologies fenestration technology in OpenStudio") and the multi-step procedure you're describing in the post itself. I'm inferring from the latter that you're likely more interested in troubleshooting that specific measure, rather than simply replacing window technologies fenestration technology (e.g. materials, constructions) in OpenStudio - I could be wrong. If measure troubleshooting is indeed what you're after, then maybe consider changing the title ...
Otherwise, changing window fenestration technology in OpenStudio is pretty straightforward. Essentially what you're describing in STEP 1 - adding a new SimpleGlazingMaterial. Of course, that new material has to be added to a new, single-layer "Simple Glazing" construction. construction.
Just to be sure, I tested both approaches using OpenStudio v3.9 ... no issues. issues.
And so that's it - you don't need a measure (STEP 2) to substitute window technologies fenestration technology using OpenStudio ...
Hard to pinpoint where the issue(s) may lie in STEP 2 (measure vs your model) without having your OSM on hand. The measure itself has interesting features (e.g. LCC), yet some limitations (e.g. no skylights, no glass doors). If you're not planning to use on using these features or are possibly hindered by these limitations, then using the measure may be seems a tad overkill.
