The EnergyPlus Climate Data Summary depends on the .stat file that has the same name and in the same folder as the .epw file. Please verify that the stat file is in the correct place
The EnergyPlus Climate Data Summary depends on the .stat file that has the same name and in the same folder as the .epw file. Please verify that So to fix the stat problem, you might need to locate the .stat file and make sure it is in the correct placesame folder as the .epw file.
