Too long for a comment.
I don't think see anything wrong with your geometry. Neither does the App:
Enable Geometry Diagnostics, and check all Diagnostic Tools. No reported issues. Try this out:
Check the run/eplusout.err file. The "Warning .. CalculateZoneVolume" message no longer appears.
I encountered this a while back. I hesitate to qualify this as a bug at this moment, as I haven't taken a deep dive yet. This would be an SDK bug, not an App bug. In a nutshell, the interzone surface pair:
... should have been forward translated as an InternalMass object in the generated IDF, as suggested here. This no longer seems to work as before, maybe linked to EnergyPlus' "new" space concept introduced a few years ago.
What I end up doing is either:
I may be missing something obvious - would love to hear from other users.
I encountered this a while back. I hesitate to qualify this as a bug at this moment, as I haven't taken a deep dive yet. This would be an SDK bug, not an App bug. In a nutshell, the interzone interzone surface pair:
... should have been forward translated as an InternalMass object in the generated IDF, as suggested here. This no longer seems to work as before, maybe linked to EnergyPlus' "new" new space concept introduced a few years ago.
I don't see anything wrong with your geometry. Neither does the App:
... should have been forward translated as an InternalMass object in the generated IDF, as suggested here. This no longer seems to work as before, maybe linked to EnergyPlus' new space concept introduced a few years ago.
| 4 | No.4 Revision |
I don't know how to combine spaces into one using the App. I may be missing something obvious - would love to hear from other users.others.
