When using ContamFMU for co-simulation, the simple air-handling system flows are determined by EnergyPlus. This is as intended by the developers of ContamFMU. One can use schedules in EnergyPlus to control these flows according to the rules established for EnergyPlus HVAC system models.
One could use other forced-flow elements in CONTAM to drive flows, and these could be controlled via CONTAM schedules.
