Hi,
I want to determine the overall cooling and heating load in my EnergyPlus model, without designing the actual HVAC system - this will serve as my baseline model which the results of which I can compare with "advanced" (modified) EnergyPlus model.
The only way I came across to do this is via defining an object in EnergyPlus called ZoneHVAC:IdealLoadsAirSystem.
Further, the Output:Variables which can help to estimate this are:
- Zone Ideal Loads Zone Total Heating Rate
- Zone Ideal Loads Zone Total Cooling Rate
- Zone Air System Sensible Heating Rate
- Zone Air System Sensible Cooling Rate
Can anyone from the community help me in understanding how can I achieve this? - any sort of guidance will be welcomed and appreciated.
Apologies, if the question is not clear enough.
Thank you!
