A basic question. What is U-Factor Times Area Value in CoolingTower:* objects?
- What area is the area? The total surface area of the cooling tower packing? The total air inlet opening area? Or the total air outlet opening area?
- The unit is [W/K]. The K seems to be a temperature difference, but where is it? The difference between the OA WB and the inlet water temperature? Or the difference between the water inlet temperature and outlet temperature?
