I am running OpenStudio SDK version 3.7.0 with the associated SketchUp Plugin, and I am running into an error when running the EnergyPlus Simulation. Despite all spaces being enclosed, I receive the following errors: In addition, the Energyplus eplusout.err log is completely empty. Why am I unable to get an EnergyPlus error log output? I have checked my geometry a lot, and it seems like everything is connected as it should.
Link to attachments: https://drive.google.com/drive/folders/1mat3Iyfv7TLlA2ati0htloL-MBhgQlPm?usp=sharing [14:43:41.279333 WARN] [utilities.Polyhedron] Polyhedron is not enclosed in original testing. Trying to add missing colinear points.
[14:43:44.655761 FATAL] [openstudio.workflow.OSWorkflow] EnergyPlus Terminated with a Fatal Error. Check eplusout.err log.
[14:43:44.655761 ERROR] [openstudio.workflow.OSWorkflow] Found error in state 'EnergyPlus' with message: 'D:\OSN\src\workflow\RunEnergyPlus.cpp@291 : EnergyPlus Terminated with a Fatal Error. Check eplusout.err log.
