Hello,
I have received the same error message across multiple OpenStudio models of varying complexity. Please follow this link for my .osm file with simple geometry that has the following error message.
Beginning the translation to IDF Assertion pl failed on line 1992 of class openstudio::model::PortList __cdecl openstudio::model::detail::ThermalZone_Impl::inletPortList(void) const in file D:\OSN\src\model\ThermalZone.cpp. stderr: [BOOST_ASSERT] <2> Assertion pl failed on line 1992 of class openstudio::model::PortList __cdecl openstudio::model::detail::ThermalZone_Impl::inletPortList(void) const in file D:\OSN\src\model\ThermalZone.cpp. onRunProcessErrored: Simulation failed to run, QProcess::ProcessError: 1 Simulation failed to run, with exit code -1073741819
I have already run the OSM Diagnostics Script and Remove Unused ThermalZones.
I tried adding a report measure of “Add Output Diagnostics” to try and diagnose the issue, but receive an error message that says "Measure Manager has crashed, attempting to restart. Do you want to reset Measure Manager settings?" And when I hit “Restore Defaults,” the program crashes.
The program also crashes when I attempt to view the geometry from the OpenStudio main interface, so perhaps it has something to do with the geometry I created in SketchUp?
I appreciate any insight others can provide! Thank you so much.
