I was recently required to upgrade to Windows 11 and can no longer run BEopt 3. The beta worked fine on Windows 10, but on Windows 11 it crashes immediately after selecting and confirming the application type. It also crashes if I open one of the sample files via the context menu. I see the two following events in the application event log:
Application: BEopt.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.NullReferenceException at NREL.BEopt.BEoptUIVB.My.MyApplication.MyApplication_UnhandledException(System.Object, Microsoft.VisualBasic.ApplicationServices.UnhandledExceptionEventArgs) at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.raise_UnhandledException(System.Object, Microsoft.VisualBasic.ApplicationServices.UnhandledExceptionEventArgs) at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnUnhandledException(Microsoft.VisualBasic.ApplicationServices.UnhandledExceptionEventArgs) at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel() at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(System.String[]) at NREL.BEopt.BEoptUIVB.My.MyApplication.Main(System.String[])
Faulting application name: BEopt.exe, version: 3.0.1.0, time stamp: 0x64133c6a Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000 Exception code: 0xc0000005 Fault offset: 0x0d4af466 Faulting process id: 0x0x7D28 Faulting application start time: 0x0x1DAD7ABB054DED1 Faulting application path: C:\Program Files (x86)\NREL\BEopt_3.0.1\BEopt.exe Faulting module path: unknown Report Id: 26a8b599-d66f-4e51-8a32-0e2176035a3c Faulting package full name: Faulting package-relative application ID:
