When I want to calculate the multiplier for the standard layer, this error occurs. When the multiplier is 1, the error will not occur the following error categories occurred. Consider correcting or noting. *** InterZone Surface Areas -- mismatch *** ..Area mismatch errors happen when the interzone surface in zone A is *** ..not the same size as it's companion in zone B. * Warning * GetSurfaceData: InterZone Surface Areas do not match as expected and might not satisfy conservation of energy: * ~~~ * Area=11.8, Multipliers=1, Total Area=11.8 in Surface=SURFACE 140 Zone=1F-BED-1 * ~~~ * Area=11.8, Multipliers=20, Total Area=237.6 in Surface=SURFACE 287 Zone=2F-BED-1
