Controller outdoorAir object Humidistat Control Zone Name
Dear Community,
I am using de openstudio package in python. I want to modify the object Controller:OutdoorAir object.
I want to put 'True' or 'Yes' for de field : 'High Humidity Control' and put the name of the zone for the field 'Humidistat Control Zone Name'.
To do this I do the following instructions :
controller_outdoorair = [CA for CA in openstudio.model.getControllerOutdoorAirs(osm)]
for index in range(len(controller_outdoorair)): controller_outdoorair[index].setHighHumidityControl(True)
It works for the field 'High Humidity Control' but It seems that there is no function for the field 'Humidistat Control Zone Name'. The instruction controller_outdoorair[index].setHumidistatControlZoneName("Zone name") does not work.
I read the documentation here : https://openstudio-sdk-documentation.s3.amazonaws.com/cpp/OpenStudio-3.8.0-doc/model/html/classopenstudio_1_1model_1_1_controller_outdoor_air.html
It sounds that the function to define the zone name does not exist.
Is it normal ?
Dear Community,
Is it normal ?
