How I can solve socket.cfg in energyplus FMU
Hi there,
I am trying to work with energyplus FMU for a simple simulation.
When I run the simulation, an exception severe error arises:
Severe ExternalInterface: Did not find file "socket.cfg". ~~~ This file needs to be in same directory as in.idf. ~~~ Check the documentation for the ExternalInterface. Fatal Error in ExternalInterface: Check EnergyPlus *.err file.
I would appreciate it if you could kindly let me know how I can address the challenge
Thank you very much in advance for your time and assistance
Sincerely, Behnam
Hi there,
Sincerely, Behnam
Hi there,
file.
Sincerely, Behnam
